Big Block Owners
Old Oct 16, 2002 | 09:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Big Block Owners
Big Block Owners
Just courious what you did to re-route your stearing.
I keep toying with the idea of droping my buick 350x and trans in my bird.
My wagon will just get up and haul a$$ and in the bird, I guess my only problem would be traction. But the stearing would be in the way big time.
I like both cars how they are but the idea of doing a switch gets my fancy now and then.
2.8 5 speed in the wagon, 350x turbo400 in the bird.
Old Oct 16, 2002 | 11:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
BBC swaps don't need steering rerouted. When using the Hooker Supercomp headers, one of the tubes is pre-dented to clear the steering shaft.
At least it's not as bad as putting a V8 into an S-10. The steering shaft has to go between the header tubes.
Using a Buick, Olds, or Pontiac engine will also require a new transmission since those 3 engines (plus Caddy) have a different transmission bellhousing bolt pattern than Chev.
Old Oct 16, 2002 | 11:57 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
:rockon: :rockon: SLAYER!!!!:hail: :hail:
Old Oct 17, 2002 | 12:08 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
not sure how it got started but that is a popular saying during the silent lul between songs at a concert. or any other evert, that real quiet part for a sec. so everybody can hear
:rockon: SLAYER :rockon:
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
