Do i NEED a valve cover breather?
Old Oct 17, 2002 | 08:26 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
I just picked up a nifty new set of valve covers, but theres no holes at all in them for any kind of pcv valve or breather. Should i start drilling some holes or will it be ok as is?
Eric
Old Oct 17, 2002 | 09:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes you need them. I would recommend simply drilling ones to match your stock ones, as much as possible (may be tough for the oil fill).
Old Oct 17, 2002 | 09:10 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
alrighty then, i'm off to drill. I'm not gonna drill a oil fill hole though, i'll just fill through the oil breather hole.
Old Oct 20, 2002 | 04:07 AM
radiateu2's Avatar
zupman
Make sure you have a pvc hole to vent your crankcase properly
Old Oct 20, 2002 | 04:15 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You don't absolutely have to have one, but I would recommend using one. By keeping the crankcase from building up pressure, you extend the life of your piston rings. Also, any unburnt fuel vapors that escape into the crankcase will be sucked back into the intake and burned off.
Old Oct 20, 2002 | 04:20 AM
radiateu2's Avatar
Ward
I agree you dont absolutely need one but for the reasons you had stated I thought it would be a good idea to mention it. I would never run without it myself for reasons mentioned.
Old Oct 20, 2002 | 10:59 AM
Iroc n roll's Avatar
The PCV is a good thing to run. However, that other breather tube that just goes to the TB straight with no valve (don't know if you have that but I know an 85 TPI car has it) can be ditched.
Old Oct 20, 2002 | 11:13 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
If you run PCV the you need both... In order for the system to work correctly the PCV also relies on the input air supply created on the other side of the valve covers " the free flow side " Under accelleration the PCV may not beable to keep up with the pressure vented to the outside so the free flow side will dump in to the intake system via air cleaner or throttle body depending on your system.. The worse the engine wears the worse it dumps...
On a new engine or an unworn engine the PVC uses the free flow side as an actual air intake so it has a place to draw from. Having no Intake air supply, it will draw from any where it can including but not always including engine oil with the mix. Don't do it.. Either have a vent to atmosphere or to the intake side.. But have one
Old Oct 20, 2002 | 12:44 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
I got it already
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
