Heater A/C not working
Old Oct 17, 2002 | 12:27 PM
nlurch80's Avatar
hey blower willn ot work. The A/C and heater i can feel it come on but not heat or A/C. What can be the problem? where is the heater blower located? I stoped and came back on and now it is all off.
Old Oct 17, 2002 | 01:11 PM
Slade1's Avatar
The fan motor is on the passenger side and is accessible from the engine bay. It's a big black box there with a motor in it. It is retained by only a few bolts, replacing it is a snap if that's your problem. Mine died on me 5 years ago, simple change only took me 30 mins.
If you drive it all the time with heat or a/c the motor eventually wears out its brushes and a replacement is in need.
Old Oct 17, 2002 | 08:47 PM
Nasty_Bird_'90's Avatar
Check the fuse first. A blower motor s $40 and a fuse is $.03. Hmmmmm.... Thats what I'd check first. Then get yourself a service manual or a chiltons and use the diagnostic charts to test all the components so you don't waste money on a motor that may not fix your problem. Thats what happened to me. My a/c/heater fuse kept blowing so I replaced the motor and it didn't fix the problem.
Old Oct 18, 2002 | 09:48 AM
nlurch80's Avatar
Heater blower
Thanks really helped!
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
