6500 rpm safe
6500 rpm safe
my car does not have much power down low but screams after 3000 rpm. Will 3.73 gears help this, and I plan on putting a 2500 stall, on my turbo 350 in the garage. My car pulls to 6500 and sometimes further when racing with it in drive. I do not know the internals of the engine in my car, but would you recomend doing a compression check to see if it is stock or not. I do not want a rod going through my block.
Car: 4
Engine: 6
Transmission: 5
You can't tell if it's stock by a compression check.
It's probably safe to 6500 a couple of times anyway. If it's just a toy, spin it till it blows. On the other hand, if this is a daily driver, I believe I'd be more cautious with it, not knowing what it's built out of.
I don't think the gears will change how much power the engine has at low RPMS, but they'll help the engine get out of that range more quickly.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
gears. My engine makes 420 FlywheelHP at 6000~ rpms. Below 3000? I cant even spin the tires. I DO run high 12's low 13's however... Going to 3.73's will give me a second or more, easilly.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Kintalon, would you mind posting your engine setup, I'm curious as to what cam/ heads you are running.
Transmission: 4l80e
Axle/Gears: 3.512
Sure. its setup for a blower but I sold the blower so now its a dog on the street. Still runs a 12 tho, and when i get my new blower (177) here in about 2 weeks it should be in the 11's easy then some go-juice maybe 10's and a new freaking car cause I will break it in 2 pieces
sreZ28
Oct 22, 2015 08:21 AM
MikkoV
Sep 9, 2015 04:25 PM
