How does this lookk, heads off, pics inside
Old Oct 20, 2002 | 06:38 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Here are some pics, any comments, as in anything look bad?
Attached Thumbnails How does this lookk, heads off, pics inside-heads-008small.jpg
Old Oct 20, 2002 | 06:40 PM
Car: 99 Formula
Axle/Gears: 342
another one.
Attached Thumbnails How does this lookk, heads off, pics inside-heads-002small.jpg
Old Oct 20, 2002 | 07:04 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
to me that looks like your running rich or the rings arent sealing very good...the first pics of the chambers....the first cylinder on the left looks like its a little lean but the next 3 look about normal...but the 2nd pic with the pistons looks a little rough...
how do your plugs look?
Old Oct 20, 2002 | 07:09 PM
Car: 99 Formula
Axle/Gears: 342
Well, most plugs look ok, but one looked like it wasn't even firing, I'd say 75% of it looked clean, with a tad of black. But I'm not sure if that was the cylinder it was off of. My ignition is pretty new, new wires, 12k miles on dist, plugs had about 5k miles on em.
Old Oct 20, 2002 | 07:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That #1 or #8 (far left in the 1st pic) was getting water in it.
The rest look perfectly normal.
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Is it possible coolant was leaking into that cylnder? That can clean your parts!
Old Oct 20, 2002 | 07:36 PM
Car: 99 Formula
Axle/Gears: 342
Shouldn't have been, though some may have gotten in there when the heads were pulled off, tried not to let any.
Old Oct 20, 2002 | 09:13 PM
rezinn's Avatar
It was leaking in, it wouldn't matter if it got in when the heads were off.
Old Oct 20, 2002 | 09:15 PM
Car: 99 Formula
Axle/Gears: 342
Water huh, was this due to a bad head gasket? Would any performance be lost because of this. Any piston damage?
Old Oct 20, 2002 | 09:43 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
looks like water got to your cylinder like mentioned above (hence the valves looking so clean. It could have been a blown head gasket. As for performance......maybe so, especially since you would have compression bleedoff as a by product. Pistons will be fine. Does that piston look clean also?? most likely will.
Old Oct 20, 2002 | 09:54 PM
Car: 99 Formula
Axle/Gears: 342
Oh, forgot till now, I did spray some water down in the engine 2 weeks ago. Think that was the cause?
Hmm, not sure, I'll have my bro take a look, I'm back at college, I thought they were all dark, not clean.
Oh,if water was getting in, wouldn't antifreeze, causing smoke? I got no smoke??
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Coolant leaking/seaping into that cylinder is correct. Besure to have the heads Mag checked for cracks. Those are the light weight casting cylinder heads. They have a reputation for cracking...
Old Oct 20, 2002 | 09:56 PM
Car: 99 Formula
Axle/Gears: 342
read my above reply, I edited it.
Old Oct 20, 2002 | 10:06 PM
radiateu2's Avatar
coolant leak
Yeah coolant leak it luteraly steam cleans the chamber like the picture. I t doesnt take much coolant to do it either. Did you ever notice the slightest hesitation any time but intermittent, well this is the cause. More than likely you might want to have the heads shave for an true surface.
Old Oct 20, 2002 | 10:09 PM
Car: 99 Formula
Axle/Gears: 342
Re: coolant leak
I've had a bad hesitation off the line for awhile, thought it was carb related.
Old Oct 20, 2002 | 10:19 PM
radiateu2's Avatar
hey Mark
I know the feeling I have a 1993 Mercury Cougar with the 3.8 v-6 always hesitated when taking off then oneday she crapped out your lucky I had to have the heads milled. I know I know its a FORD but the same principle apply water fuel and spark dont mix. I bet your ET's and 0-60 will be much better running on and not seven when she is fixed
Old Oct 20, 2002 | 10:24 PM
Car: 99 Formula
Axle/Gears: 342
Re: hey Mark
well, I'm gettin new heads, Sportsman IIs, new 650DP carb, and new Hooker 2055 headers, if it don't run right after this, I'm goin to cry.
Oh, and I own a Ford too, nothin wrong with it, 90 Stang 30mpg.
makes modding the IROC possible.
Old Oct 20, 2002 | 10:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Mark, how many miles have you put on that engine?
If I remember correctly its fairly new, but it seems like you got alot of carbon build up on the pistons.
Old Oct 20, 2002 | 11:00 PM
Car: 99 Formula
Axle/Gears: 342
About 12k miles.
radiateu2's Avatar
good ole MD fuel
Its that good ole nasty unleaded in the mid atlantic states plus it does look like he was running a little rich ok maybe a lot rich
Old Oct 20, 2002 | 11:08 PM
Car: 99 Formula
Axle/Gears: 342
that one piston was scraped to see if it had any # on it.
Attached Thumbnails How does this lookk, heads off, pics inside-heads-005small.jpg
Old Oct 20, 2002 | 11:14 PM
radiateu2's Avatar
running real rich
Man Mark that is a lot of Carbon for 12K I took my 305 with over 100,000 and it didnt look that bad. You very well could of had a carb problem as well.
The gas is still nasty there lol
Old Oct 20, 2002 | 11:30 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
BTW Mark.......
Those are cast stock, dished pistons to answer your question on the other thread.
AJ
Old Oct 21, 2002 | 12:32 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
That wasn't a water leak. That was just the only one that was burning half good. the rest are way too rich.
When you get a water leak that cylinder will be real clean.
that is nothing. Inspect your head gasket. If there was a problem you will see it.
Did you ever overheat the motor?
Mark how thick is the head gasket? Rotate the motor to bring the piston to the top (TDC) and see how far down the piston is in the bore.
Were going to have to help ya tune a carb, cause that is real rich.
Old Oct 21, 2002 | 09:39 AM
Car: 99 Formula
Axle/Gears: 342
When I first got the motor within the first 2k miles or so, the motor did run rather warm a few times it got to 240*.
Old Oct 21, 2002 | 10:36 AM
9-FIREBIRD-2's Avatar
heads
I kinda like that day glow green thing you got goin on there in the pics too.
Old Oct 21, 2002 | 10:48 AM
F-BIRD'88's Avatar
Gees Eh 240*.... And any wonder why SOME PEOPLE
have trouble with factory head gaskets ........
Old Oct 21, 2002 | 11:04 AM
Car: 99 Formula
Axle/Gears: 342
yeah, I didn't like it runnin that hot either, I later found out it was due to my small crank pulley I had on there.
Old Oct 21, 2002 | 11:16 AM
Steve86TA's Avatar
Car: To many to list
Thats a ton of carbon build up for 12K
Old Oct 21, 2002 | 12:00 PM
Slade1's Avatar
I was burning oil in my car due to o-rings starting to give on the pistons, but when I pulled the heads, they didn't look that bad. Yeah some carbon build up, but not sludge thick.
From my guess is you were running rich. The others look steam cleaned. Steam cleaning does wonders. I use that concept to clean my headers if I spill oil on them, I get them real hot then spray with some light water, instant steam and instant clean...
Old Oct 21, 2002 | 12:06 PM
Car: 99 Formula
Axle/Gears: 342
Well, that one may look worse, because I took those pics after WD-40 was sprayed into the cylinder.
Old Oct 21, 2002 | 12:54 PM
rezinn's Avatar
Hey Mark, tell your brother to drain the coolant before he removes stuff, that way it won't drain into your lifter valley and oil pan
Old Oct 21, 2002 | 01:14 PM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
Hey Mark,
Why are you going with a DP carb? Aren't you supposed to get a VS carb with an automatic tranny and DP with a manual? I know you have an auto because I remember you have the B&M T-handled autoshifter.
EDIT: I made 100 posts today!
Old Oct 21, 2002 | 01:38 PM
Car: 99 Formula
Axle/Gears: 342
We did try to let it drain out the heads best we could so no coolant would get down there. We soaked up all we could with rags to, after the pics.
Old Oct 21, 2002 | 01:39 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by MuttandJeff
Hey Mark,
well, technically, you can use a DP, but you can't just mash the gas, it takes some skill. My brother has had numerous auto/DP combos, and said to go with it.
And others have told me the same on here.
Old Oct 21, 2002 | 01:42 PM
TBI305Camaro's Avatar
Ive talked to some people and they say double pumpers work great with automatics....
Mark...my 305 with 113k looked a tad worse than that....pull a valve and see how much buildup is on there because your motor looks pretty nasty for 12k miles.
You need to figure out whats up with that motor mark....16 second quater on an engine that supposedly comes with 250hp + the cam...check your cat maybe its fried?
Old Oct 21, 2002 | 01:46 PM
Engine: 5.0 TBI
I was just wondering, since everyone on the carb boards and the tech articles say that for autos you should use the vacuum secondary carb and for manuals to use mech. secondaries.
I guess that's more for swappers who are switching from FI to carb and have no experience with driving carb motors.
Old Oct 21, 2002 | 02:53 PM
Car: 99 Formula
Axle/Gears: 342
actually, also DP can have vac secondaries too.
Old Oct 21, 2002 | 06:52 PM
Engine: 5.0 TBI
I thought double pumpers were mech. secondaries. I learn something new everyday....
Old Oct 21, 2002 | 07:08 PM
Car: 99 Formula
Axle/Gears: 342
actually 15.49 thank you.
Old Oct 21, 2002 | 07:46 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
There is no such thing as a DP with VS
Old Oct 21, 2002 | 08:15 PM
  #42
Car: 99 Formula
Axle/Gears: 342
Yeah they do.
Old Oct 21, 2002 | 08:32 PM
  #43
DABE's Avatar
*looks in to crystal ball* i see some world heads in the near future*
DABE
Old Oct 21, 2002 | 10:22 PM
  #44
My bad mark...something is still wrong...some stock LO3s have turned those times...you cant tell me something isnt up. Get those new heads on there and report back to us ASAP.
Old Oct 21, 2002 | 10:49 PM
  #45
Guest
Guest
Posts: n/a
The first cylinder, way too clean. Probably water getting in there.
Second, a little rich.
Third looks ok.
Fourth is without question running rich.
Carbon buildup looks ok to me, nothing totally out of the ordinary. I've seen MUCH worse.
Frozer!!!
Jan 19, 2024 04:55 PM
project89
Sep 24, 2015 06:38 AM
qz6lwp
Aug 20, 2015 08:10 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
