Here's an important tip I had to learn the hard way
Old Oct 23, 2002 | 05:41 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
When installing a harmonic balancer, make sure the front key is in the crankshaft. When I had my engine out about 3 months ago, I guess the front key fell out of the slot in the crankshaft. Well, I installed the harmonic balancer anyways because I never noticed. Just last week I was driving down the freeway and I had a bad vibration coming from the engine. At first i thought it was a misfire, but when I got off the freeway and I got out of overdrive, I could feel how bad the vibration was. I limped the car home, and I noticed that the rubber on my harmonic balancer was coming out a bit, so I thought maybe the outer ring rotated out of position, causing the engine to be out of balance. I pulled the harmonic balancer out and realized that the keyway was ground up bad, due the the fact that the balancer had only been sitting on the back key, the one for the timing sprocket. Without the front key installed, I guess the force of the engine overpowers it.
So you guys can learn from my mistake, make sure the front keyway is in whenever you install a balancer! I'll try and get a pic of the damage to the balancer.
Old Oct 23, 2002 | 06:29 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I couldn't see your balancer falling off to be a good thing!!! Good to hear that you were able to get it home alright.
Old Oct 23, 2002 | 07:07 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ouch!
Old Oct 24, 2002 | 01:59 AM
LarsZ28's Avatar
Now you've got me all worried about mine
Breazlan
Sep 25, 2015 11:20 AM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
89 formula TPI
Sep 8, 2015 08:00 PM
Randomtask2
Sep 7, 2015 05:06 PM
