Can I reuse these lifters?
Old Oct 24, 2002 | 04:29 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I assume since i have flat tappet lifters that they are junk when i go to get a new cam since they are already broken into the stock cam but it never hurts to ask. Can i reuse my old flat tappet lifters? They only have ~4k on them.
Old Oct 24, 2002 | 05:50 PM
kevinc's Avatar
Car: 1982 Z28
Sure you can re-use them, it's your engine. I wouldn't do it on mine. New set of flat tappets is less than $100 and the consequence of running old lifters is prematurely-worn cam lobes.
Old Oct 24, 2002 | 06:26 PM
Car: 88 Camaro SC
Engine: SFI'd 350
well, obviously i could just put them back in. But, like you said and i thought, not without accelerated wear on the lobes. Thanx for the reply.
Old Oct 24, 2002 | 08:55 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You don't ever want to re-use flat tappets with a new cam. Putting the same ones back on the same cam... OK I guess as long as you put them all back in the same spots.
But a full set is cheap. I paid under a hundred bucks for my cam AND lifters. They're so cheap that there's no reason to take a chance.
b4ccamaro
Jun 5, 2016 01:48 PM
skinny z
Oct 5, 2015 06:23 PM
WhteRbt
Sep 21, 2015 09:48 AM
dimented24x7
Sep 6, 2015 03:51 PM
