Comp. Ratio
Old Oct 24, 2002 | 09:16 PM
speedfreak85's Avatar
Comp. Ratio
What's the highest compression ratio I can run on 93 pump gas with iron heads?
Old Oct 24, 2002 | 09:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
10:1 I believe it is.
Old Oct 25, 2002 | 01:57 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I wouldn't venture much beyond 10:1. Different heads will have a slightly different absolute detonation point. But will not vary that much.
Better to snug up the cr to a usably close but safe level for the fuel your going to use and concentrate on airflow improvements to get your target horsepower level.
You can make serious horsepower at 9.8:1.
Old Oct 25, 2002 | 02:13 AM
ronterry's Avatar
Car: '94 Corvette
Heck, up here in the Rockies, I would bet you could go to 11:1.
--That's of course if you could find 93 at the pump. Most of are gas is 91 for premium & 87 for regular.
High altitude has that slow burning effect on fuel like higher octane does.
Ron
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
