leaky clutch fluid resevoir?
Old Oct 24, 2002 | 09:38 PM
primer84z's Avatar
i have to refill my clutch fluid resevoir about once a week and can never see where its leaking. it doesnt drip out on to the ground becuase i never see it. any suggestions/or common causes and fixes for this? thanks.
Old Oct 24, 2002 | 11:27 PM
chacane67's Avatar
Do you have an aftermarket clutch?
Old Oct 25, 2002 | 06:31 AM
ede's Avatar
ede
the entire system doesn't hold much oil so a small leak would drain the system, or at least reduce it's level ,but i na week you should see a spot i believe.
Old Oct 26, 2002 | 01:35 AM
primer84z's Avatar
in answer to the above question, its a stock replacement clutch done last year.
Old Oct 26, 2002 | 09:47 AM
Vader's Avatar
Take a closer look at the slave cylinder.
Old Oct 26, 2002 | 11:06 AM
primer84z's Avatar
thanks for the help. i had a football game last night so i dont really feel like messing with the **** today, but i get after it tomorrow.
Old Dec 6, 2002 | 06:14 PM
primer84z's Avatar
where do the lines run from the resevoir under the hood to the clutch? i guess they could have installed my clutch wrong. do i have to drop the tranny to get to the slave cylinder? thanks for the help.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
