Spark plug + wires change...HELP
Old Oct 26, 2002 | 05:53 PM
The_Prostitute's Avatar
I am planning on changing my spark plugs and wires tomorrow and was wondering how hard its going to be and how long it should take. I believe I have all the required tools. I have changed spark plugs and wires before but not on a Camaro. Can anyone give me any tips or hints that may make my job more successful?
I have a 1992 Chevy Camaro RS TBI, V8
Old Oct 26, 2002 | 10:02 PM
Vader's Avatar
Make sure you have a decent gap gauge and an open end wrench to fit the hex collar on the spark plug socket. You'll probably need to use the wrench instead of the ratchet on #6 and #8.
This would be a good time to test teh plug wire resistance, too. Plan on a couple hours for the whole job.
Old Oct 26, 2002 | 10:11 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Just depends on how many times you've changed plugs before. It could take anywhere from 20 minutes to an hour. make sure to route the wires underneath the manifolds. Not too many people do this and end up wondering why there is an extra 2 feet of wire. Good luck.
Old Oct 27, 2002 | 07:06 AM
Please explain what you mean by rotating the wires...
Old Oct 27, 2002 | 07:45 AM
Sciguyjim's Avatar
He said route not rotate. He means to position the wires under the manifolds rather than above them.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
g.l.mos
Aug 22, 2015 12:02 AM
