Tire Pressure
Old Oct 26, 2002 | 10:27 AM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Tire Pressure
HEY GUTS WAS JUST WONDERING WHAT THE BEST PSI. WAS FOR 235\60\15 TIRES?
THANKS
Old Oct 26, 2002 | 11:10 AM
ede's Avatar
ede
best for what? i usually run the max manufacurer preasure, or a hair more on the street
Old Oct 26, 2002 | 11:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Experiment and see. Most of the ones I've had work best with 34-35 front and 23-33 rear.
And please lose the all-caps; it's extremely difficult to read, very rude to those whom you expect to heplp you out, and makes it unlikely that anyone is going to try to bother to slog through all that to figure out what you're saying. There are no excuses ("It's easier", "I only type with one hand", etc.) that make it OK.
Old Oct 26, 2002 | 11:51 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Or if it's the stock size for the tire, look on the inside of the door. GM puts what they think is the best pressure.
Old Oct 26, 2002 | 12:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
i always run the max tire pressure stated on the tire its self. It makes the car handle much better and just feel tighter.
Old Oct 27, 2002 | 07:59 AM
Sciguyjim's Avatar
My tires are similar in size (215/65 16") and I find that I get the most tread contact with the street at about 38 psi. My door sticker says to use 30. The tire mfgr says using 40 psi is too high but 38 is ok. I tried using the max pressure listed on the sidewall (44 psi) once but my tires began to wear more in the center than at the edges.
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
mike_c
Aug 27, 2015 04:32 PM
g.l.mos
Aug 22, 2015 12:02 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
