Maf keeps going out .
Old Oct 27, 2002 | 09:27 AM
WaynesRS's Avatar
About 2 months ago , I replaced my MAF sensor . Sence then I have put 3 maf's on it . They were all bad . I know this because I tested it with a MAF sensor tester , plus after I would get a new one , the car would run great for a few weeks before my MAF would start to take a crap on me again .Now Im thinking , there must be something wrong to keep making my MAF sensors go bad like that .What do you guys think ? Thanx !
In addition to this , I have also knowticed some oil in the airtube , which runs behind the maf sensor to .( my maf sensor is located right after my air filters .
Old Oct 27, 2002 | 01:48 PM
WaynesRS's Avatar
ttt
Old Oct 27, 2002 | 04:35 PM
rezinn's Avatar
I've never seen a MAF sensor tester, how does that work? You have changed your power and burnoff relays, right?
Old Oct 27, 2002 | 04:57 PM
WaynesRS's Avatar
No , I have not changed the relays , but could that keep making them go bad ?
It has three lights on it , you test it by revving the engine , letting it idle . The lights will blink , stay on . I think when it blinks , its not working right , something like that , I have the little manual on it . Thanx for the help man .
Oh , yeah and you test it by piercing the wire slightly with a needle , it pierces it so slightly that when you take the wire off , you cant even see the hole . another part of the sensor hooks up to a ground .
Old Oct 27, 2002 | 09:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Swap your burn off relay, it's probably what's frying every MAF you put in. Search the site for MAF and Vader, you'll find a cool little pic of where the relays are.
Old Oct 27, 2002 | 09:47 PM
WaynesRS's Avatar
cool , Thanx man !
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
