Ugh!!!!
Old Oct 29, 2002 | 10:16 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
Ugh!!!!
Ok ive asked everyone! at least 3 times now and i cant seem to get it fixed ok choke light comes on everytime the car starts (then idles at like 1500 rpm normally) hesitates everytime i hit the gas raises in rpms but doesnt seem to go or sumthing like that and to make matters worse if you didnt know my alternator died yesterday and now this https://www.thirdgen.org/techbb2/sho...hreadid=140988 what could be wrong they said that they "were not carborator certified and to try soemwhere else" so i think im getting the run around but could someone explain whats goin on in my car please! i just cant take it anymore!
Old Oct 29, 2002 | 10:41 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Did you get that alternator problem fixed yet?
Old Oct 29, 2002 | 10:51 PM
Car: Camaro
Engine: 5.slow
no becuase the guy said that it was working fine and that there wasnt any problem with it (even thou it was ideling at 1500 rpms which was probably why it was he thought it was working now that i think about it) note: he used a fancy tester thingy what do u guys think? if i exchange my alternator and thats not what was wrong with it then i just wasted $80.00 or so dollars.
But i guess i have nothing to lose exept my car problems....
Old Oct 30, 2002 | 08:57 AM
helloriker's Avatar
Well I doubt that what ever is causing your problem is the alternator. When the car is running it runs off the battery which is then charged by the alternator, so if the alternator goes bad eventually you get a dead battery. It usually doesn't take to long either. Your problem sounds more airflow related, you should look for a carberator place in your phone book. Because carbs are so old now alot of shops don't know how to work on them. And there are a lot of shops that are setup to work just on carbs. Anyway I hope you get your problem fixed. Please correct me if I am wrong, but I don't think I am
Old Oct 30, 2002 | 09:13 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
You have to be "carburetor certified"?
Old Nov 6, 2002 | 03:40 PM
helloriker's Avatar
I don't think you need any certifications to do the work. But most shops don't work on carbs anymore. Some do and others don't. You need to find a shop that works on carbs.
Old Nov 7, 2002 | 09:23 AM
Vader's Avatar
STM,
You probably have more than just a choke problem, since even with an electric choke, the engine and carb will eventually warm up and run normally. If you are leaning out after the engine is fully warmed, you may have other issues.
Old Nov 7, 2002 | 10:21 AM
Morley's Avatar
Originally posted by Vader
STM,
Assuming that the choke is operating correctly and not stuck closed or partially closed.
I'd pull the air cleaner assembly once the engine is warmed up and look at the choke plates to make sure they are fully open.
SBlackfoot
Jun 27, 2003 06:32 PM
Trans-it
May 2, 2003 01:05 PM
Trans_AM_88
Mar 13, 2003 06:04 PM
ClarionedCanuk
Oct 22, 2002 08:36 PM
ninety1TAgta
17
Oct 14, 2002 11:43 AM
