What are the tolerances/clearances on a SBC?
Old Oct 30, 2002 | 08:35 PM
Nasty_Bird_'90's Avatar
I'm getting ready to assemble the bottom end for my L98. What I need to know are the clearances, like crankshaft endplay, rod side clearances and main/rod bearing clearances. If any of you know this info or have a link to it, please help me out. Any info is appreciated. Thanx.
Old Oct 30, 2002 | 08:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Maybe try a search if you don't get any answers tonite. Lazy bastard. that's what you get for calling me one.
Old Oct 30, 2002 | 08:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On a street motor I usually shoot for .001"-.0015" on both main and rod bearings. Crank end play should be in the .010"-.025" range, not particularly critical, as long as there is some, but the throws don't hit the block or anything stupid like that; look for rod side clearance about .012"-.016", again not extremely critical. The crank should spin more easily as you torque the main bearings. DO NOT over-torque anything, more damage can be done this way than if they are at the low end of spec; use white lithium on the bolts as anti-seize. Only measure torque while bolts are turning: that's why I don't care for the clicker-type wrenches, I like a beam type or dial type. I usually use 65 ft-lbs on the mains, 35 on the rods. I prefer thin lube for building; either ATF or 5W-30 synthetic. Of course if you're using a flat-tappet cam, use dino juice for at least the first oil change, you can switch to synthetic after that.
Old Oct 31, 2002 | 05:48 AM
ede's Avatar
ede
you really ought to consider spending 20 dollars or so and buy a manual, never know what sort of info someone might give you on the net.
Old Oct 31, 2002 | 10:59 AM
laiky's Avatar
1.5 is the minimum spec according to chevy and every other engine builder, 1.0 is not reccommended
Go buy a manual or you will regret it, something that TEACHES YOU HOW TO BUILD AN ENGINE, because if you have to ask these questions you'll just **** it up!
Try Chevy Power Book, lingenfelter on SBC's or a factory shop manual.
Old Oct 31, 2002 | 11:30 AM
Thanx for the info guys. I'll go out nd buy a manual. W
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Damon
Sep 26, 2015 04:29 PM
