Elec.Fuel pump running after shutoff
Old Nov 1, 2002 | 02:47 PM
JoseyWales's Avatar
I have a 92 RS with the 6cyl. fuel injection
I just replaced the electric fuel pump. Is it normal for the pump to run about 15 secs after the car is shut off?
I don't remember this before. Thanks
Old Nov 1, 2002 | 10:02 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
It sounds like a relay is stuck on or something. I don't know if your car has one but it might be worth checking out.
Old Nov 3, 2002 | 09:56 AM
Vader's Avatar
Outlaw,
That's completely normal. The fuel pump is powered by both the fuel pump relay AND the auxilliary oil pressure switch. As long as there is residual oil pressure (above 4-7 PSIG), the pump will run. In colder temperatures, the oil pressure bleeds off more slowly, so the fuel pump will run on a little longer.
This diagram should make that clearer:
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
