Crank Pully Removal
Old Nov 2, 2002 | 08:25 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Crank Pully Removal
If anyone is currently online reading this and knows the best way to remove the center bolt holding the crank shaft pully on, I am working on the car now and can't get it loose. Please post immediately, Thank You
Old Nov 2, 2002 | 08:52 PM
Slade1's Avatar
To get mine off I used a wedge on the alternator fan with the belt at tension keeping it still...
You could just save the hassle and use an air gun.
Old Nov 2, 2002 | 09:07 PM
ede's Avatar
ede
impact wrench, if you don't have one use eomething to hold the belt or wedge a screwdriver in the flexplate
Old Nov 2, 2002 | 11:04 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks for the replies,I ended up making a wooden wedge and putting it between the power steering pump pulley and the crank pulley . I was unable to use any of the belt tension to help because I have already removed some accesories . This did come to mind(the wedge),but since I didnt have a wedge laying around,I tried to use stuff like hammer handles and other various items for about an hour, that just slipped out.It took about 4 minutes to cut the wood with a hand saw and another 30 seconds to get the bolt off! Oh well,that was enough for me tonight,I'll be back at it in the morning.
anesthes
Mar 10, 2016 10:35 PM
angel2794
Sep 8, 2015 06:22 PM
mddaniel
Sep 8, 2015 05:16 PM
Night rider327
Sep 2, 2015 04:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
