Piston ID Problem
Old Nov 6, 2002 | 12:22 PM
Mark W. Winning's Avatar
Piston ID Problem
I am looking to ID a set of pistons in a motor I pulled down. The piston is stamped L2244. Might be an old TRW number that is no longer in the new catalogs. If anyone has a older book, it may be in there. I am looking for compression ratios.
Mark
Old Nov 6, 2002 | 01:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What bore is it? How deep is the dish? If you measure the dish you can calculate the volume directly and you have no need for books.
Old Nov 6, 2002 | 01:07 PM
Its a 30 over 350 flattop piston with 4 valve reliefs.
Mark
Old Nov 6, 2002 | 08:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well that's pretty easy... it's a flat-top. Other than that, the valve reliefs are usually around 4cc. Compression ratio will depend on the heads and head gasket you use, and the deck clearance of the built-up short block. Just use 4cc as the "dish" volume in your CR calculator, you'll be as close as any of that will ever get you.
angel2794
Sep 8, 2015 06:22 PM
Mickeyruder
Sep 2, 2015 02:45 PM
masonta
Sep 1, 2015 06:40 PM
JHX
Aug 29, 2015 02:30 PM
LT1Formula
Aug 20, 2015 09:36 PM
