poping through carb
Old Nov 6, 2002 | 06:53 PM
Zya's Avatar
Zya
poping through carb
I have an 1986 z-28 305 lg4 automatic 32,000 miles. It poped like 3 times while accelerating going up a hill and wanted to die so i let off the gas and got on flat land reved it up a few times and it was fine after that. I had the carb rebuilt it has orginial plugs wires etc.... any ideas?!?!
Old Nov 6, 2002 | 07:31 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Popping thru carb usually means a lean condition.
I'd check the timing, choke, and I also had a similar problem when I had a burnt plug wire.
Old Nov 6, 2002 | 08:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
rockers could be too tight
Old Nov 7, 2002 | 09:10 AM
Vader's Avatar
Zya,
At 32,000 miles, it's time for a 30K service:
* Axle gear oil change;
* Transmission oil and filter change;
* Front and rear brake service - wheel bearing repack;
* Underbody/bushing and body weatherseal lubrication;
* PCV system inspection;
* Oxygen sensor replacement;
* Air and fuel filter replacement;
* Distributor cap, rotor, spark plug replacement, and plug wire test;
* Set TPS, mixture control solenoid, choke, and idle stop (Yes, you have a TPS);
* Cooling system flush & refill, condenser and radiator cleaning;
* Vacuum hose/fuel system inspection.
* Belt and hose inspection/replacement.
Getting current on your scheduled service might solve part of your problems.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
