ignition problems
Old Nov 8, 2002 | 03:03 PM
armymp1983's Avatar
ignition problems
hey i bought my 1988 camaro in august from a warrant officer here in germany. been having problems starting it. sometimes it cranks and sometimes it doesn't. it usually gives me problems first thing in the morning. then during the day it runs fine. whe i turn the key i get a repeated clicking sound. can anyone help me i have had it in the shop several times and the germans don't seem to be helping me much. any help would be greatly appreciated.
:hail: :hail: :hail:
Old Nov 8, 2002 | 06:40 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
clickiing sounds like a starter problem...thats what mine did before the starter completely died
Old Nov 8, 2002 | 10:38 PM
Vader's Avatar
MP,
Welcome Aboard!
Does the clicking come from the engine comparment or inside the passenger compartment? If it is from under the hood, you likely have a starter solenoid failing, or possib;y a connection problem at the solenoid, battery, or engine ground. You may also have a starter motor brush problem if the click is very distinct but you get no cranking.
If the clicking is from inside the passenger compartment, you may have a problem with the neutral safety/clutch safety circuit, or the start enable relay.
Old Nov 9, 2002 | 01:39 AM
Axle/Gears: 3:08
in case you havent heard....vader is the man to listen to....if he says it its almost always a sure bet.........
Old Nov 9, 2002 | 08:53 AM
Vader's Avatar
...as long as you're only betting with Monopoly money (or scrip)....
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
