Those who have went TBI to carb i need help.
Ok Im getting about 7psi of pressure (after the mallory FPR) only when i first prime the key then the pressure stops. I dont think my fuel pump is staying on. I reconnected 3 grounds that were on the back of the heads.
What do i need to do to keep the fuel pump on while the key is on? bypass the relay? if so how do i do this.,
Simple fix!! I had the same problem. Find the relay for the fuel pump. Turn the key forward and pop the relay off. Get a tester wire. Just keep touching the metal parts on the relay together two at a time until the fuel pump turns on ( I forget what (2) colored wires to put together). When it turns on just splice those two wires an butt connect, solder or put together by any other means. Your done, a little mickey mouse but nobody will know and it will work fine.Good luck
alright thanks ill try that.
the car ran earlier and started right up but it got alittle colder and it wont start now. Im still messing with the fuel pressure and it isnt helping.
where is the fuel pump relay?? on the drivers side firewall? beside the brake booster?
509 camaro fan
Sep 6, 2015 10:43 AM
