oil guage connection?
Old Nov 8, 2002 | 05:43 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Since I put in the 77 350 I havent been able to get my oil gauge to work. anyone know how to fix it? it is pinned to the up possition. it doesnt move nomatter what. all the other gauges work thnks
Old Nov 8, 2002 | 05:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That means the wire isn't hooked up, assuming that it comes down when you turn the key off. If it stays pinned even with the key off, then it's a mechanical issue with the gauge itself.
It's a dark blue wire with a big round rubber boot sort of connector on it. The sending unit is a can about 1¼" diameter by 2" long, right behind and under the distributor.
Old Nov 8, 2002 | 05:48 PM
SHAGME's Avatar
Car: 1988 IROC-Z
no its pinned always. it was working b4 the swap. where is the hook up for it? I cant remember taking it off. thnks
Old Nov 8, 2002 | 06:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old Nov 8, 2002 | 06:09 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ok thnks but I dont remember seeing it there. Il look again thnks. I would have thoght it was lower down though thnks
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
tgp1990
Sep 4, 2015 06:24 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
