Air Cleaner Parts...
Old Nov 10, 2002 | 03:26 PM
z28redline's Avatar
Car: 1986 Camaro Z28
Engine: 305 lG4
I have a l69 duel snorkal air cleaner that I am re-painting and I was wondering if someone could tell me what the following part is and how to take it off
-The gold ring thing that looks like a filterbut is about an inch and half thick.
Z28redline
Old Nov 11, 2002 | 03:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's a carbon (charcoal) filled container that absorbs fuel vapors that escape from the float bowl when the engine isn't running.
When the engine is started, fresh air passing through the charcoal pulls the vapors out to be burned in the combustion process.
To take it off, you need to desolve the adhesive that's got it glued to the base. If you want to re-install it, good luck ("mechanical" removal is the more-likely-to-be-successful method).
Old Nov 12, 2002 | 12:17 AM
z28redline's Avatar
Engine: 305 lG4
Is there any reason to leave it on? It seems that it would only decrease the air flow.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
