Oil pan removal
Old Nov 10, 2002 | 08:19 PM
MD83Z's Avatar
Oil pan removal
Y pipe is removed
Engine is jacked up (think bellhousing is against firewall/floor)
Counterweighs up
Still can't get the oil pan to clear the bottom of the bellhousing.
The pan is weged by the engine up front,the crossmember in the middle and bellhousing in the back. A dent in the pan might get the 1/4" I need for clearance.......... Who has removed pan with engine in car?
Search shows some have done it except Damon said trans had to be pulled back (so thats an engine pull if your that far)
Old Nov 10, 2002 | 08:26 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
check the thread about "Changing an oil pan on a Camaro" below for more info, or a search. I have done it, not fun but possible. I mention in the other thread about pan differences that can make or break the in car pan change. Good luck with it.
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
