will a truck oil pan work?
Old Nov 11, 2002 | 07:02 PM
capn_crash84's Avatar
The engine i'm building for my car came from an 78 chevy truck. The oil pan looks a little different, so i thought i better make sure it will work in my 84 trans am. The old engines (305 lg4) oil pan was close to the cross memeber, so i don't want to drop it in and find out it wont clear it. Thanks alot.
aaron
Old Nov 11, 2002 | 09:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The truck pans generally won't work in these cars or A & G bodies, the sump extends too far forward and hits the exhaust. A 2nd gen Camaro pan will work, or one out of a Chevelle or Monte Carlo or Cutlass or any such, as long as it has the driver's side dipstick. Avoid full-size cars and trucks, their frames have more room, and their pans usually won't fit these cars. I use the old Z28 pan that gives a 6-quart system, but that one requires a windage tray, it is not optional.
Old Nov 11, 2002 | 10:29 PM
If the sump extended forward, wouldn't it hit the crossmember? I'm going to be using full length headmen headers with s pipes, so would that change anything? I took the trucks oil pan out to the garage and compared it to a pan i took off of a 305 i pulled from an 86 trans am. It looks identical except the dipsticks are on opposite sides.
thanks
aaron
Old Nov 11, 2002 | 10:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you use the full length headders it will work but its going to be close. Theres a 2in differece between the two pans. Some trucks came with the same small pan though.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
