fuel line return?
Old Nov 11, 2002 | 09:27 PM
PIMPINPHIL's Avatar
fuel line return?
hi,
i have a external fuel cell,with a external fuel pump,but what do i do with my return line?my fuel cell doesnt have a place for it,it has to fuel line feeds,and 1 vent line,thanks
is it needed,or could i just block it off?
Old Nov 12, 2002 | 08:15 AM
Vader's Avatar
PP,
If you're using a 3-line electric pump, you definitely need the return line or risk damaging the pump in a short time. You may be able to rig a return fitting to the vent line, but should still have a vent with a surge valve when you are finished.
Old Nov 12, 2002 | 08:28 AM
PIMPINPHIL's Avatar
hi,
my fuel pump is the nos one in the summit catalog,pretty sure its just in and out,so i could get some kind of "y" fitting on my vent line??thanks for your help.
Old Nov 13, 2002 | 07:52 AM
Vader's Avatar
Am I reading that correctly? A stock pump? If you needed to install a regulator to control fuel pressure, you probably needthe return line.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
