clutch spring making sound
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
everytime i let up on the clutch pedal it makes a sound. so i guess it has to be changed. so how would i go about changing it?
can i do it myself?
can i do it myself?
More likely a throw out bearing and/or release arm than a spring, but anything is possible. In either case, the transmission has to be removed. that requires removal of the driveshaft, center crossmember, shift and clutch linkages, VSS wiring, torque arm mounting, then the transmission. Once the transmission is out you can inspect the throw out bearing and release mechanism without removing anything else, and should find the noisy little devil, whatever it is.
That, of course, all depends upon whther the noise is from inside the car or under the car.
Car: 92 Z28 Z03
it only started the other morning but it has been wet out for a couple of days. it seems to have stopped for now. but it seems like such a pain to remove all that stuff.
Thanks for the info guys.
theshackle
Sep 17, 2020 08:26 AM
novaderrik
Aug 10, 2015 12:44 PM
rsrmoore
Aug 7, 2015 08:44 PM
