gotta few error codes..help me fix
Old Nov 14, 2002 | 02:58 PM
SmuurF's Avatar
i did the thing with tripping the aldl..worked perfect..great instructions :hail: ...anyway ive got codes:
34-MAP sensor voltage high/pressure high vacuum low
34-MAF signal high-FLow low
42-EST circuit grounded (HEI module failure)
44-oxygen sensor lean error
45-oxygen sensor rich error
help me fix these so my car can stop stallin in tha middle of tha road
Old Nov 14, 2002 | 03:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like the first thing you should do is clear all those, and start over. It's pretty hard to troubleshoot a lean condition and a rich condition at the same time, for example; they may have occurred under totally different conditions over who knows how much time.
Old Nov 14, 2002 | 03:09 PM
SmuurF's Avatar
how do i do that?
Old Nov 14, 2002 | 10:36 PM
86TATpi's Avatar
Easiest way is to disconnect the negative battery wire for a little bit and connect it again. Or if you don't want to lose stations or time on your radio or whatever there is a ecm power line around the battery you can unclip.
Old Nov 14, 2002 | 10:52 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
grenrally multiple codes like that are a ECM going out . first try clearing and see what comes back first .
mike
Old Nov 15, 2002 | 12:20 AM
rezinn's Avatar
I seriously doubt your ecm is bad. That isn't even a lot of codes. You probably should change your oxygen sensor and reset the codes. You may need a new MAF, or a relay.
Old Nov 15, 2002 | 10:01 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
what year vehicle is it? what type of fuel system? TBI, Carb, or TPI? that would help to see if u have a MAF or MAP sensor. what if any, symptoms are you having? that would help diagnose the problem.
David Frans
Oct 31, 2015 08:12 PM
NZKnight
Oct 15, 2015 02:47 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
