How can I disable the fuel pump?
Old Nov 16, 2002 | 02:05 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I'm trying to do a compression test and, as the intake and fuel rails are off, every time that I go to crank the engine, I end up with a nice big puddle of gas on top of and below the engine.
So I just need to keep the fuel pump from priming when I turn the key. How can I do that?
Old Nov 16, 2002 | 02:06 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I don't have fuel injection so I'm not 100% positive but there should be a fuse labeled 'fuel pump' or 'fp', yank that and it won't turn on.
Old Nov 16, 2002 | 02:08 PM
ede's Avatar
ede
on a camaro the fuel pump fuse is on the inner right fender near the battery in a little black plastic houseing. firebirds are differant location but i can't remember where
Old Nov 16, 2002 | 02:12 PM
sancho's Avatar
Ukraine Train: There was a 10 amp fuse labeled "F/P inst" or something like that; I pulled it and it still primed...
ede: I know what you're talking about; thanks!
Old Nov 16, 2002 | 02:38 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Either pull connector off fuel pump relay (drivers side firewall-outer one-relay with grey wire coming out of connector).
or disconnect plug just above rear axle on the floorpan kick-up.
Andy.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
