How to lash valves for LO3 with LT1 cam- any different than Haynes method?
Old Nov 17, 2002 | 10:04 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
I learned how to lash valves according to the haynes manual method-
#1 piston TDC, do all of the specified intake and exhaust valves, then turn it 360* to #6 and do the rest. This IS the correct way to do it with the stock cam.
When I did a comp 280H cam in another car, comp has another method, by basically doing each valve independantly. This IS necessary with this cam because I was curious and tried a couple valves using the Haynes method and they were either too tight or too loose as soon as you turn the motor.
so,
An LT1 cam is obviously lumpier than the LO3 cam. What method is correct for lashing an LO3 with an LT1 cam in it? Using 1.6 roller rockers by the way. I have my own preferance for tightening the rocker after achieving zero lash, it's just the tightening order I'm not sure about.
Old Nov 18, 2002 | 02:26 AM
rezinn's Avatar
The valves are pretty much in the same place on the camshaft with either cam, so lashing them with either method should work. Doing the adjustments with the motor running can't fail.
New2Chevy
Sep 28, 2015 12:35 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
dimented24x7
Sep 6, 2015 03:51 PM
L0tuS
Sep 4, 2015 11:16 PM
