dip stick 305 to 350 block Q
Old Nov 22, 2002 | 08:53 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Will any chevy 350sb dip stick work in any chevy 350sb ?
I know a 305 dipstick register marks won't be true for a 350.
Also, is there an o-ring or sealant to use when replacing dipstick?
Thanks!
:hail:IROC-Z
Old Nov 22, 2002 | 08:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends...
Any driver's side dipstick will work in any driver's side dipstick block, 262 / 265 / 267 / 283 / 302 / 305 / 307 / 327 / 350 / 400; except for around 78-79, when they made them go into the side of the pan instead of into the block. Any pass-side dipstick will fit into any pass side dipstick block. CID doesn't matter for any of this, because the marks do not care about, or even notice, the cylinder diameter or the crank journal offset.
No O-ring. Use silicone on a driver's side into-the-pan setup to keep it from weeping.
Always replace the tube and dipstick as a set, because they aren't all exactly the same length, and that can cause them to register incorrectly.
Old Nov 22, 2002 | 09:06 AM
TBI305Camaro's Avatar
I used my 305 lo3 dipstick in my new 350 lo5 and the marks are the same.
Old Nov 22, 2002 | 09:09 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Re: dip stick 305 to 350 block Q
[QUOTE]Originally posted by rocky383
[B]I know a 305 dipstick register marks won't be true for a 350.
Guess I was wrong about that. I appreciate the info.
:hail:IROC-Z
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
