Post UR ENGINE!! VROOOOM
Old Nov 29, 2002 | 04:12 PM
  #101
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
350
sorry about the dirty airfilter, it has been replaced
Old Nov 29, 2002 | 08:59 PM
  #102
CHEVYTOWN's Avatar
Modified L6 mated to a 2004R
Old Nov 29, 2002 | 10:14 PM
  #103
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Hey Zepher, whats up with the FE heads? Is that a B-body LT1?
Old Nov 30, 2002 | 02:01 AM
  #104
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Yeah, that is a B-Body LT1 350 from a Caprice.
Only thing I am using from it is the block. If I could go back in time knowing what I was planning on doing, I'd have just got a 4bolt main LT1 block, since almost everything on my LT1 is coming off.
I've got LT4 heads, LT4 Intake, LT4 Hotcam, Forged TRW Pistons, gonna get some Eagle Rods, new pushrods, possibly new lifters, I'd like to get a new crank, electric waterpump, etc....
I bought that complete LT1 for $1000, sold the heads for $125 and the intake for $75.
Old Nov 30, 2002 | 07:32 AM
  #105
HybridZ28's Avatar
Hmmm
Old Nov 30, 2002 | 10:31 AM
  #106
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
that picture wasnt of my engine. it was somebody on the first page of this thread. anyway, he talked about it some i think. i posted it because i doctored it some to make it look like mine as far as the colors of everything. but, if you are curious about what was moved and stuff....i think the owner posted about it on the first page of this thread. good luck searching through all those posts
Old Dec 10, 2002 | 09:10 PM
  #107
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
its a little late but......
Old Dec 11, 2002 | 07:03 PM
  #108
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mines a real sleeper, hehe.. no pics, but the 350 came out of a '79 Z28, but now has the deceased L69's aluminum intake, manifolds, carb, dual snorkel air cleaner/scoops and valve covers. Its not much for motor, prolly around 200hp/275ft-lbs but its a hell of alot more fun than the 305 it often passes for, hehe :lala:
Old Dec 11, 2002 | 07:05 PM
  #109
Air_Adam's Avatar
... in the summer sometime, the 350 will be rodded-out a little more though. I plan on headers, true duals (sidepipes?) possibly a functional cowl hood (2.5"), new intake and probably a new cam and/or roller rockers.
i'm guessing that would boost it to about 275-315hp, no?
Old Dec 11, 2002 | 09:15 PM
  #110
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
just a little 355
Old Dec 11, 2002 | 09:55 PM
  #111
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
can someone tell me what exactly an "edelbrock performer rpm" manifold does?? why is it better? i have one on my car and i dont even know why. AND are Carter competition carbs any good? cause i have a 4bbl one and i dont know if i should upgrade.
Old Dec 12, 2002 | 12:27 PM
  #112
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Here is mine
Old Dec 12, 2002 | 07:38 PM
  #113
Car: 1984 Z28
what
Old Dec 12, 2002 | 09:58 PM
  #114
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
MINE
heres my pos
Old Dec 12, 2002 | 10:30 PM
  #115
TBI305Camaro's Avatar
here you go.
Old Dec 12, 2002 | 10:41 PM
  #116
Snowdog 91 Formula's Avatar
Dang I lost all my pics of my engine... maybe there are 1 or 2 if you do a search on here lol.... I think I have to talk my friend into taking some pictures.
I have no dyno figures on my motor but I have been told anything from around 275-320 horse.
I believe the former because I need to get the $#%#@% engine tuned to to the computer.
Old Dec 13, 2002 | 05:57 AM
  #117
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Mine
Old Dec 13, 2002 | 08:38 AM
  #118
Dang those lt1/lt4s sit low down in there dont they. Least you know you will never have clearance problems with the stock hood like I do. How hard was it to hook up all the wiring and stuff on the lt4?
Old Dec 13, 2002 | 06:22 PM
  #119
HybridZ28's Avatar
Hehe Yeah Hood Clearence will never be a problem.
The wiring is not to bad, Things go along better if you use a current FI car to do the swap on.
Old Dec 15, 2002 | 05:23 PM
  #120
Car: 1984 Z28
ahem... cough
Old Dec 15, 2002 | 06:43 PM
  #121
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
heres the ol' daily beater... See sig for engine combo.
Old Mar 9, 2003 | 07:20 PM
  #122
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
haven't done anything to the beast....yet
Old Mar 9, 2003 | 08:10 PM
  #123
chymos's Avatar
Ok, I'll bite. Just promise you won't laugh at my empty wallet.
used circa 1980 crate 350 with 426 heads, Hedman shorties, Performer intake, and a Holley carb.......not worthy of pics, obviously
Old Mar 9, 2003 | 10:47 PM
  #124
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Here's mine...
330hp Lo3:
it's dirty...but it's fast!
Old Mar 10, 2003 | 12:35 AM
  #125
86budgetSC's Avatar
Here is the motor going in my truck.79 350 4 bolt main.Stock lower end.(no ring ridge)Comp cams 270h cam,(.470 lift with 224 duration @ .050)Comp cams hydralic lifters,comp cams double roller timing chain set,melling high volume oil pump,Summit chrome oil pan.(I know it looks black in the pic.)Not sure on what to do for heads.Might use the pos's I got for a while.Going with a weiand stealth intake,The holley 600cfm carb I got.Not sure on igntion.Probably hedman headers with 1 5/8 primarys.
Hoping to be in and running by summer.I am hoping for over 300 horse.
Old Mar 10, 2003 | 04:55 PM
  #126
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Here's mine -
Old Mar 10, 2003 | 10:51 PM
  #127
Car: 1984 Z28
wow, the thread is ALIVE AGAIN!!!
Old Mar 11, 2003 | 08:38 AM
  #128
EvilCartman's Avatar
Car: '82 Z28
Cool, a chance to update mine Taken last night when I put the new Demon 750 on for chits and giggles.
Old Mar 23, 2003 | 10:34 AM
  #129
ninjairoc's Avatar
Car: 1986 Camaro IROC-Z
when you guys paint the engine bay, do u just take it to a paint place or what??? how do you manage to paint it? did you need to take everything out? And what the hell is bead blasting?
beadblasting is like sandblasting if you've ever heard of it, instead of using sand they use small glass beads that are blasted through a gun run off an air compressor to remove the old paint or clean the metal, etc.
Old Mar 23, 2003 | 02:25 PM
  #130
Car: 1984 Z28
what the hell is the difference? its used for the same purpose as sand isnt it?
ps. its been really nice out here and i finally got to license the camaro. YEE HAW! had it out tuesday, got a ticket wednesday
Old Mar 23, 2003 | 02:38 PM
  #131
ninjairoc's Avatar
yes it's used as the same purpose as sand. But there are many types of blasting abrasives from glass, sand, plastic, to walnut shells. They are all used for different types of metal. Some would do damage to one kind of metal while the other type of blasting media would be fine. They all have their purpose.
Old Mar 23, 2003 | 08:21 PM
  #132
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
here`s mine
Old Mar 23, 2003 | 08:22 PM
  #133
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
ok how do you post pictures?? damn rookies...........
Old Mar 23, 2003 | 08:32 PM
  #134
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
you have to get the picture on the internet. easiest way is to put it on your readers ride page, and then use its address when youre posting it.
Old Mar 23, 2003 | 09:05 PM
  #135
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Here's mine! I love opportunities to post pics of my engine
and
Holley says 425 HP at 6125 rpm and 425 ft lbs of torque at 4250 rpm or so....someday I'll get it on a chassis dyno and see what she's got at the rear wheels
-Paul
Old Mar 24, 2003 | 11:23 PM
  #136
batman63's Avatar
This went in last summer...
  #137
batman63's Avatar
This went into engine bay last summer...
Old Mar 24, 2003 | 11:25 PM
  #138
batman63's Avatar
Last summer's project
Old Mar 24, 2003 | 11:34 PM
  #139
87Formula4bbl's Avatar
Car: '87 Formula
Not quite finished yet...
Old Jun 8, 2005 | 05:37 AM
  #140
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Here's mine. Yeah, it's dirty. Been sitting at the exhaust shop waiting for me to bring new springs for header to ground clearance. Still a work in progress.
Old Jun 8, 2005 | 02:24 PM
  #141
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Here is my old engine when I pulled it out:
Old Jun 8, 2005 | 09:23 PM
  #142
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Heres mine. Just got er in there a few weeks ago. Runnin around 375HP.
Attached Thumbnails Post UR ENGINE!!  VROOOOM-hell-ya-5-22
Old Jun 8, 2005 | 09:24 PM
  #143
Engine: 355 chevy
Another.
Old Jun 8, 2005 | 10:26 PM
  #144
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I have to add mine for posterity. I think I'm lucky if I'm pulling 180 HP:
Old Jun 8, 2005 | 10:28 PM
  #145
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
A SBC out of a Mustang?!?
Old Jun 8, 2005 | 10:44 PM
  #146
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
the allmighty stock lo3!
Old Jun 9, 2005 | 01:20 PM
  #147
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Man, I have a completely stock '89 LO3 I have never cleaned it (84k miles) and I white glove that block and return with some dust on it maybe.
Old Jun 9, 2005 | 05:30 PM
  #148
Tibo's Avatar
Car: 1991 Z28 Vert
LOL. That is my dad's Cobra. My Camaro is to the left of the picture. It is a fairly big garage/shed.
Old Jun 9, 2005 | 07:53 PM
  #149
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
nothing special but here you go.
Old Jun 9, 2005 | 10:44 PM
  #150
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
no biggie here: chevy 357 in 84TA
