Oil
Old Nov 23, 2002 | 04:47 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
Oil
ok well i had a problem with my old valve covers on my new 350, it has 61 miles on the new engine and they leaked, i replaved them, put on the gasket and the sealer, tightened them down and let them sit for 2 days
well i changed my oil yesterday and while i had it in the air i started to pour in the new oil and it was just pouring out the back of the engine, the valve covers arent leaking now, but somewhere else on the engine is pouring out oil, i know its not the dipstick hole, and i dont think its the oil pan because its dosent hav oil on it, but its dripping down onto the crossmember and then onto the ground
so does anyone know what i should do to try to fix this or waht things i chould goa nd check out. thanks
Shean
Old Nov 23, 2002 | 05:01 PM
snakeskinner's Avatar
are you sure the back of the intake is not leaking? I bet this was the problem all along. also, check the oil sending unit near the driver's side of the back of the intake.
Old Nov 23, 2002 | 09:32 PM
Squeeks83's Avatar
well i reached around the best that i could and found no oil, i went with my fingers then some paper towls, thanks so ill go check that in the morning.
Shean
Old Nov 23, 2002 | 10:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hey, could you shrink your sig pic just a tad, so it doesn't run over the page, scrolling back and forth to read is a pain, thanks man.
Old Nov 23, 2002 | 11:19 PM
Squeeks83's Avatar
what too long or what...?
Shean
Old Nov 23, 2002 | 11:23 PM
Car: 99 Formula
Axle/Gears: 342
Shean
too wide, yeah, just shrink it's width just a bit. thanks.
Old Nov 24, 2002 | 01:49 PM
Squeeks83's Avatar
no problem
Shean
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
