Mating SS fuel line with stock hard line???
I want to replace the rubber fuel line going from the top of the fuel tank to the 3/8" hard line with stainless steel braided line, but what do I use to make the connection? The only thing I can think of is to cut the end off, and put on a flare fitting (which I have no experience doing), and using a flare to AN adapter. Is this the right way to do it?
Or you could clean the steel line thoroughly, install a steel compression fitting / flare adapter for the 37° fitting. These are sold by the handful at places that supply hydraulic fittings, and hold a lot more pressure than your fuel system will ever develop.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
