Tuning my tpi****HELP*****
Old Nov 25, 2002 | 09:08 AM
aaronkark's Avatar
Hello I have an 88 formula 305tpi. My problem is with tuning the beast. I can set the timing perfect with the tan black wire disconnected but as soon as I shut the car off and connect it and start the car the timing is no longer set. Does anyone have an idea of what the problem might be. And it runs like crap until it is warmed up. Thanks, Aaron
Old Nov 25, 2002 | 09:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds normal to me. That's what it's supposed to do.
Old Nov 25, 2002 | 09:13 AM
aaronkark's Avatar
You mean its normal for the timing not to stay set and for the car to run bad?
Old Nov 25, 2002 | 09:45 AM
Vicious 88 GTA's Avatar
Same Problem Here
Hey man I have the same problem like you do, I can set the timing perfect but unless the car is at like 120-140 degrees it will run fine, if not it will sputter or misfire....AARON...p.s. cool name
Old Dec 1, 2002 | 10:46 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
After you re-connect the timing wire, did you remember to unplug the computer and let it reset before starting the car??? The timing advances alot with that wire connected. Its what the computer is supposed to do. But after you disconnect that wire, and set the timing, you have to restart the computer. Un-hook your negative batt. cable for like 5 minutes or something.
After you start the car, its going to run rough at first. The computer has to "re-learn" what its supposed to do. Get in, and drive the car above 40mph for about 15 minutes. At 40mph the car goes into "learning" mode. Try that, see what that does. If you have done all that, then just ignore my babbling...
Justin
Zell1luk
Sep 29, 2015 10:36 AM
