Post pictures of you computer controlled carb setups please
Old Nov 27, 2002 | 07:36 AM
Momar's Avatar
I am trying to reconnect all of my stuff after about a year of it being apart. I think I am getting there but some pictures that show wiring and so fort would be great. If you have any with the air cleaner assembly off that would be perfect. Also pics around the egr(and stuff it connects to) would be nice. Also I think there is a wire that grounds on the intake manifold. What color wire(s) does it have running to it and where on the intake does it bolt to?
Thanks a lot
Ben
Old Nov 27, 2002 | 08:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'll snap a pic of mine later on....
The ground is black. It goes on the bolt that holds the top alternator bracket to the intake. It's pretty obvious; it has a ring terminal, while every other wire in the ECM harness (totally separate from the harness for the rest of the car) has some kind of Weatherpak connector on it.
Old Nov 27, 2002 | 09:33 AM
Momar's Avatar
I found 2 that have ring connectors and I think both of them have 2 wires. I know which one goes to the front because of where it is positioned. Does the other go to the back of the head?
Ben
Old Nov 27, 2002 | 11:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. Back of the pass side head. It can go under the same bolt with the ground braid strap to the firewall and the blower motor ground.
eightsixseven
Dec 16, 2024 01:50 PM
pimp2303
Jul 27, 2017 02:03 PM
midge54
Jan 29, 2017 07:00 PM
LittleFranks
Aug 20, 2015 03:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
