Can clogged fuel filter cause backfire?
Old Nov 29, 2002 | 02:19 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
My car is still backfiring under heavy acceleration. I changed the plugs and tightened up all of the exhaust. It still boggs down a little under quick acceleration. I think the fuel filter might be cloggged but can that cause backfire? When i step on the gas, my air/fuel gauge says it gets really lean but when I let off it gets really rich and then goes back to normal. All i really wana know is can a clogged fuel filter cause backfiring?
Old Nov 29, 2002 | 02:39 PM
Hung Start67's Avatar
fuel filter
Sounds like to me you may have a timing,ignition problem. The fuel filter if clogged will make it run very bad maybe even to the point of backfiring or not running at all. Change the filter then check that timing..Bottom line thou keep it simple..I thought I had a major problem myself turned out the wires, plugs, cap and rotor were shot. start with the obvious then go from there..
Old Nov 29, 2002 | 02:43 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Re: Can clogged fuel filter cause backfire?
I would say: Yes, a clogged fuel filter could cause backfiring from the lean condition. I'm not saying that's the problem though!
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
