better than expected
Old Nov 29, 2002 | 09:53 PM
NuclearPwrIroc's Avatar
Hey guys. I have a 172,000 mile L98. When i went to change the header gaskets (dang stock edelbrock gaskets) i pulled the plugs, ran a compression and leak down test....got 135psi dry and wet cranking compression. and i had only 6-7% leak down...not bad huh? think nitrous would be a bad idea? haha. shows what regular maintenece will do?
Old Dec 1, 2002 | 10:48 AM
Vader's Avatar
All those sliding parts DO like to have a clean supply of oil. I have experienced the same sort of thing on higher mileage engines. I'm a believer in synthetics, and have had good, measurable results after extended use.
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
