Harmonic Balancer
Old Dec 1, 2002 | 09:52 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Harmonic Balancer
Will a harmonic balancer off a 305 fit/work for a small block 400? How about a 350? Also, can any of you recommend a good, cheap balancer if that swapping WON'T work? Thanks.
Old Dec 1, 2002 | 10:58 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
do a search, somewhere there's a GM advertisement that says a 305 damper is the same as a 350 damper. Not sure about the 400 though, since it's got a different crank. Maybeit's in the article
Old Dec 2, 2002 | 12:41 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If I'm nor mistaken it wont work on a 400" crank.
Old Dec 2, 2002 | 01:46 AM
FrozenFirebird's Avatar
To my knowledge you should be able to interchange the harmonic balancer from a 305 to a 350...They are both internally balanced engines, where as the 400 is not, and requires a larger balancer as well as a different flex plate/fly wheel
Old Dec 2, 2002 | 06:32 AM
ede's Avatar
ede
all SBCs are internally balanced and the dampners are nutral balanced, except the 400, don't use anything on a 400 except a 400 dampner.
Old Dec 2, 2002 | 10:34 AM
Nixon1's Avatar
Thanks guys!
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
