Low duration, high lift...
Old Dec 2, 2002 | 01:07 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Very generally, what affects will a low duration high lift cam produce?
I have a 196/206 roller cam and I'm going to be running 1.6 ratio rockers soon. This will produce .460/.481 lift.
I know that most cams with low duration like this usually don't have this much lift...that's why I'm curious.
thanks
Old Dec 2, 2002 | 02:03 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
not positive on this one, but i believe it will more or less cause a very LOW rpm torque curve. You'll get alot of power down low, but it will probably sign off by 4500 rpm or less. I know they make truck cams with the same theory in mind, use short duration and huge lift to make lots of torque down low...
not postive, just my guess...
Eric
Old Dec 2, 2002 | 10:21 AM
Vader's Avatar
Hmm...
Pretty good for just a "guess".
Old Dec 2, 2002 | 10:24 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
so does that mean i was right? that really was just a guess...
Eric
Old Dec 2, 2002 | 01:04 PM
CamaroDriver's Avatar
Eric
Yea..... you're right.
The low duration is good for low rpm torque. That's why most stock cams are this way, ESPECIALLY trucks.
By popping the valves open farther, there's less restriction under the valve. MORE AIR=MORE POWA!!!!!
Old Dec 2, 2002 | 10:19 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Cool. Thanks for the replies.
I dunno if I'm going to stay with this cam or get a 2032 CompuCam.
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
