Base ignition timing
Old Dec 2, 2002 | 04:01 PM
John Manson's Avatar
Hi, All. Anyone out there driving a stock 1990-92 5L TPI Z28? If so, would you look at the emissions sticker on the underside of the hood and let me know what the base timing should be? I have heard several educated gusses from 0 to 10 degrees advanced. Where I live the car has to pass emissions testing so I want it to be right. Thanks.
Old Dec 2, 2002 | 05:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Base ignition timing
From the '92 Camaro service manual (the real one):
LB9 & L98: 6 deg BTDC @ 600 RPM.
RBob.
Old Dec 2, 2002 | 07:56 PM
Damon's Avatar
6* is the factory remommended setting. Make sure you disconnect the timing wire before setting it or you'll be way off.
With a stock chip you can pretty much bank on 10* working a little better for performance without affecting drivability or emissions at all.
Old Dec 3, 2002 | 08:24 AM
Thanks for the info.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Bryan F
Aug 18, 2015 02:28 PM
