How light can I make an 88 Formula?
Old Dec 3, 2002 | 12:48 PM
mygrain's Avatar
Building a race car, what can I do to shed some weight? Im already ditching the sound deadener as well as most of the interior.
Old Dec 3, 2002 | 09:07 PM
Pontiacman's Avatar
Are you legal to race with a fiberglass hood, doors, front fenders, rear deck lid. Lightweight aluminum rims, driveshaft, Aluminum heads, lighter pistons, flywheel, harmonic balancer, Aluminum water pump and radiator. case of slim fast., hahaha just kidding.
Old Dec 3, 2002 | 09:43 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Try getting rid of that big rubber spoiler. Or replacing all of those big heavy suspension and brake components with better and lighter aftermarket pieces. If this is a drag only car, you can eliminate a lot of weight getting rid of those huge sway bars, which will also help your launch. Obviously remove all the unnecessary power accessories. You can remove a lot of wieght from a car but it can be expensive depending on what you simply remove and what you replace with a lighter component. How fast is this car going to be?
Old Dec 4, 2002 | 07:48 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
All good examples,
and puttin the battery in the rear will help as well.
Old Dec 4, 2002 | 10:11 AM
mygrain's Avatar
Depending on the power of my engine build up, somewhere between 11.99 and 10.99. We'll see how far my budget will take me.
Old Dec 5, 2002 | 01:08 AM
MdFormula350's Avatar
its going to be quick!
Old Dec 5, 2002 | 08:07 PM
mygrain's Avatar
thats what im hoping for
Old Dec 5, 2002 | 08:33 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You could just remove the doors, hood, hatch and windshield.... but I don't think tech would like that too much..... Reminds me of a joke...
You might be a hot rodder if...
If you shaved off your window tint to save weight.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Sep 17, 2020 08:26 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
