starting problem, please help
Old Dec 4, 2002 | 12:57 PM
5.0L1992RS's Avatar
Recently every once in a while i have been having a little trouble starting my car. The SES light is not on. When i turn the key to start the car, all it does is click and that is it. I turn the key back, then try it again and it works. The battery is fine, and the alternator is working just fine. They are both almost new. I have no idea what the problem is. Any help is appreciated.
-Kevin
Old Dec 4, 2002 | 02:20 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
check the ignition switch...
Old Dec 4, 2002 | 04:47 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Do a search on the board for this. I and several other people have had the same problem. It all came down to a starter in most occasions. I had to replace two starter before it was fixed. But if you do a search you will fine several threads on this.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
