edel. performer manifold
Old Dec 6, 2002 | 08:19 PM
BlueByU's Avatar
Car: 1991 Z28
I have and edelbrock performer manifold for the "old style" pre-86 heads. I'd like to put that manifold on my 91z 305 then put the motor in my truck so i can put my new motor in my car. So, is it possible to convert that manifold to accept the new style heads of the 305? Or would it be easier to find a used manifold that fits properly?
Old Dec 7, 2002 | 08:54 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
From my knowledge it's possible, but you'll have to do a little fabrication to the bolt holes on the intake, like drilling them straight down, maybe someone who has done it can explain.
Old Dec 7, 2002 | 11:22 AM
TBI305Camaro's Avatar
Just the center bolts are different. Im pretty sure you can drill them out to make them work.
Old Dec 7, 2002 | 09:36 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i did the same thing but an 87+ manifold on old heads. it took a lot of grinding the holes out to where the bolts go. you also need to cut the part where the bolt seats to so its flat. i ground it out with a drill bit then a grinding stone to clean it out and had the machine shop cut it so its flat.
Old Dec 7, 2002 | 10:05 PM
Bort62's Avatar
5 minutes with a Die grinder is all it will take.
Old Dec 7, 2002 | 10:56 PM
Is it a fool proof modification?? Ill probably have to make my 87+ work with 86 and older this summer when I swap heads.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
