i'm writing an essay and need your help...
Old Dec 8, 2002 | 12:06 PM
KsKid's Avatar
what are some of the major ways that magnets are used in cars? thanks alot guys
Old Dec 8, 2002 | 12:20 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Any thing that is electrical and has to move, like a starter motor
or fuel injector or solenoid. or altenator.
On some cars even the goove box is held shut by a magnet.
How about the magnetic pick up in the distributor or crank sensor.
Any thing electrical that converts motion into electrical energy
or the reverse, electrical energy into motion uses a magnet.
(And a coil).
Old Dec 8, 2002 | 01:00 PM
Bort62's Avatar
Yup.
The also use huge electro Magnets to pic cars Up at the crusher
Or Magnetic #'s At the track.
lol
Old Dec 8, 2002 | 01:03 PM
kevinc's Avatar
Car: 1982 Z28
The injector pintles are actuated by electromagnets.
Old Dec 8, 2002 | 06:02 PM
Vader's Avatar
The alternator, starter, and injectors use electomagnets as well, not true magnetized material.
If you mean "magnets" (like AlNiCo), there are magnets in the cooling fan motor(s), HVAC blower motor, tape deck transport motor, wiper motor, VSS, window motors, hatch pull-down motor, power seat and mirror motors, headlight motors (on Firebirds), transmission pan on automatics, differential covers on Saginaw and Borg axles, the oil drain plug on some later cars, and several other places I'm probably overlooking.
If you meant "magnetism", that would include all of those places listed above, plus the alternator, starter, injectors, power door locks and hatch release, the ignition coil, ignition pickup coil/reluctor, spark plug wires (for supression), every relay your car uses, the SIR firing coil on later cars, the TCC solenoid, EGR solenoid, EVAP purge solenoid, electric horns, A.I.R. port and divert solenoids, every choke coil in the radio, air conditioning compressor clutches, the IAC stepper motor, and several other places I'm probably overlooking as well. Many early carbureted ThirdGens have idle speed control and mixture control solenoids, too.
So much for stock ThirdGens. For other vehicles there are many other uses of magnets and magnetism:
Aftermarket alarm systems can use magnetic reed switches as proximity sensors for doors, hood, etc. In case you were thinking about the wheel sensors and pressure modulation motors on ABS equipped cars, most of those sensors are inductive (Hall effect) and not true magnets. However, even Hall effect proximity sensors use a electromagnetic coil to create a cone of magnetism around the sensing coil, so they use magnetism too. This also applies to the crankshaft position and cam position sensors on many newer cars. Cam position sensors on some GM engines used an inductive type sensor that had a magnet embedded in the camshaft sprocket. (Some Buicks may still use them - I'm not sure.) Transmission shifting solenoids on 4L60Es and most other newer transmissions are electromagnets. A lot more cars are getting remotely operated doors (motors), rear wipers, variable valve timing (solenoids), ride level control motors and solenoids, power sun/moon roofs, multi-zone heating and air conditioning (more relays, solenoids, and motors), inductive (magnetic) sensors for cam and crank position and wheel rotation, magnetic reed switches for washer fluid, coolant, and oil level monitoring, etc.
Let us not forget, there are also a lot of cars running around with magnetic aftermarket parts, like the Magnetic Fuel Saver. These are permanent magnets. They don't really provide any valuable function, but they do work as intended (the primary design purpose of these devices is to separate a fool from his money - something they seem to do very well).
I'm sure someone else will come up with even more.
Old Dec 8, 2002 | 06:24 PM
KsKid's Avatar
wow thats alot, before anyone else runs out of breath i dont need any more. heh thanks alot though
InfernalVortex
Apr 20, 2021 11:31 AM
Zane Story
Oct 8, 2015 12:40 PM
skip91
Sep 24, 2015 03:29 PM
R13_Braz
Sep 18, 2015 05:00 PM
louishenry
Aug 28, 2015 09:41 AM
