Need specs on L98 from 89' IROC-Z
Old Dec 11, 2002 | 03:10 PM
Penix's Avatar
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
Got a mint condition L98 short-block from an 89' IROC-Z... problem is, though I know it came stock with a 9.3:1 CR, I don't know what cc the stock heads were nor do I know the stock head gasket measurements. The cc of the pistons would be a nice addition if anyone has those, but if not, well I can figure that out given the other numbers. Anyhow, I greatly appreciate the help!
- Penix
Old Dec 11, 2002 | 03:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The heads should be 58cc, as far as the rest I'm not sure.
Old Dec 11, 2002 | 10:37 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Iron headed L98, which came in fbodys, had 64cc chambers. Aluminum headed L98s had 58cc chambers.
Old Dec 12, 2002 | 07:27 AM
Penix's Avatar
I know the heads were cast, so I guess the heads were 64cc... anyone got casting numbers on these heads?
Okay, that's one part out of the way, now how about the head gasket specs?
Thanks again Y'all
- Penix
Old Dec 12, 2002 | 07:37 AM
I have this in backup, should be pretty accurate:
350 / L98
Bore - 4.000
Stroke - 3.48
Dome CC - 0.0
Relief CC - 6.0
Head gasket - 0.031
Deck height - 0.015
Chambers - 64.0
Top ring depth - 0.280
EDIT: Actually this isn't the bible, its also says a LT1 has a 3.9" bore and a 3.66" stroke which is bs.
Old Dec 12, 2002 | 08:38 AM
Penix's Avatar
I get 9.31:1 CR with 64cc heads, 10cc pistons, a 4.166" x 0.041" gasket, and a 0.015" deck. Any of this sound about right? Cause I'm getting around 9.95:1 with your combo and I know these things only had a 9.3:1 CR.
BTW- That 3.900" Bore / 3.660" Stroke combo you have there is to a new LS1. Probably just a misprint, but then again, it can't be right about the specs to the L98.
Are Y'all sure these didn't use steel shim head gaskets? I'm pretty sure these blocks had a .025" deck and larger than 10cc pistons.
- Penix
FormulasOnly
Jul 23, 2018 08:47 AM
88CamZ
Oct 8, 2015 10:29 AM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
