oil prefrance
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
oil prefrance
ok guys what oils would you use
also how good is the redline synthetic oil?
and does anyone have (vader I think your being called here) a list of stats for each oil... you know pour rates, viscosity, ash... all that ****
Car: 91 Red Sled
Rear diff gets any brand straight weight oil since it's a torsen unit. The tranny gets what ever is cheapest.
Motor gets Castrol GTX 10w-30 all year round with only AC Delco oil filters, either PF35 or PF1218.
I figure if I change the oil ever 3000 miles it's better than leaving synthetic stuff in for twice that. Maybe if I was using those complete seal rings and didn't have to worry about fuel getting into the crank case I would use synthetic. I just can't justify the cost when compared to friends of mine that spend $$$ on their oil and have just as many if not more problems then my car. I've just got too heavy of a foot so oil doesn't matter, it's the interval between changes that's more important. Just don't use Penzoil engine oil, it seems to break down a lot faster, not sure why but that's been my experience.
You wouldn't even really consider using a mineral oil in a turbo, would you? With the tight clearances, high load, and heat of the turbine, mineral oil will turn to ash in nearly no time. The oil cooler and turbo lines will fill with carbon coking and soot, and you'll be hunting for another cartridge in short order.
You were just joking, right?
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I agree with Vader. I've had 2 turbo cars of my own. When I got them both of them had severe coking in the turbo. Most people I know, including myself, ran synthetic oil and used a turbo timer. Using dino juice is like smoking. slow premature death.
Transmission: 4L80E/4L80E
Originally posted by Mark A Shields
Amsoil I hear is the best but hard to find.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Amsoil and Redline are the best two in my opinion.
Mobil 1 is good also and it's easier to find locally (at any Kragen)
I run Mobil 1 in my engines and Redline in trannys and rearends of my three cars.
-Rich-
-Rich-
Car: 2005 BMW 545i
Engine: 4.4L N62B44
but I was thinking about using synthetic myself
one question I have about synthetic though is I hear problems of it not burning clean
is that so or do I have nothing to worry about?
If you're letting it get into your combustion chamber, it won't burn as clean as gasoline. But, it won't have any more non-burning constituents than petroleum.
The AMSOIL 10W30 full synthetic was formulated with turbo applications in mind. None of that coking stuff mentioned above.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
need to burn oil
more or less they have a setup to let oil into the intake manifold to help lube the apex seals
Is that "controlled leak" adjustable?
You could likely get by with less lube going directly into the camber with synthetic. I know a bunch of 2-strokes have been using AMSOIL 2-stroke oil at 100:1 and more, vs. normal 25:1 or 50:1.
Car: 99 Formula
Axle/Gears: 342
You're kidding, right? How hard is it to find www.amsoil.com ? Or, "Oils, Lubricating" (or whatever your region calls it) in the Yellow Pages?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Sorry, I should have clarified, I meant at local stores, like Wal-Mart, Autozone.
just don't tell me you try to buy stuff for your motor at wal-mart
I can just see it now
"blue light special at walmart on all cranks. half off normal sale price"
and there goes mark trying to get as many as he can
Car: 91 Red Sled
Originally posted by rx7speed
cheap store will only carry cheap stuff
have a rotary...
need to burn oil
have a rotary...
need to burn oil
skinny z
Oct 5, 2015 06:23 PM
