What RPM to set minimum air with a cam?
Old Dec 12, 2002 | 09:20 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Im running a Hot cam and wanted to know what RPM to set the minimum air to. When the idle dropped to 575 on the stock chip with the IAC plugged in it would stall so Im pretty sure it will not idle with the minimum air set at 400RPM. Should I set it the lowest I can without it stalling?
Old Dec 12, 2002 | 09:32 AM
Brian'sIROC's Avatar
That's what I did. I just turned the adjusting screw in far enough so that it would run with the IAC disconnected, then slowly turned it out until it was barely running.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
perZ
Aug 15, 2015 01:17 PM
TreDeClaw
Aug 14, 2015 06:58 PM
