Gm Hei
Old Dec 11, 2002 | 08:53 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Gm Hei
I don't know if their all different but I have a vac. advance HEI distributor that is stock and I was wondering how much mechanical + vaccuum advance they pull... err maybe I should say, what kinda timing should I get out of it?
Old Dec 11, 2002 | 09:44 PM
gruveb's Avatar
Car: 1989 IROC-1
You have a computer control ignition/fuel system. It's kind of a transition from carb to fuel injection, and not as good for performance as either. They are reliable though.
As far as an answer to your question goes; just as much advance as anything else can give you.
Why do you ask?
Old Dec 11, 2002 | 10:02 PM
dans82bird's Avatar
Engine: 302
Read the sig.. I took out the ccqjet and distrib. a while ago.... in place is a holley 600 and an accell distributor.. I have another hei distrib (stock gm, vaccuum adv.) and was wondering what the stock #;s on it were
Old Dec 12, 2002 | 12:03 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
You can get way more timming out of the distributor than a sbc needs. I like the crane cams kit, comes with an ajustable vaccum diaphram, weights, springs, and limiter. Haven't used one on a sbc in a long time, but when I did my 400 Pontiac a couple years ago I had to limit the amount of advance to 34*. If yours isn't worn out, they're decent pieces.
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
