blower motor only works on defrost???
Old Dec 12, 2002 | 06:26 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
It works fine in all settings on defrost, but with the vents set to any other position I get nothing. Any ideas? THANKS
Old Dec 12, 2002 | 07:41 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
buddy of mine had the same problem... he figured out it had something to do about when he hooked back up his coolant lines etc after doing his intake swap... might wanna look into that. he only gets any type air out of the defrosters... or at least until he fixed it!
Old Dec 12, 2002 | 08:26 PM
Vader's Avatar
Just a guess, but that almost has to be the function selector switch.
Old Dec 12, 2002 | 09:13 PM
irocz's Avatar
Car: '87 IROC-Z
the hot/cold air part works fine. It's just that the blower motor only comes on when the selector is switched to defrost.
Old Dec 12, 2002 | 09:38 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
his is the same way... hot/cold works... just he can only get air to come out of the dash...
Old Dec 13, 2002 | 04:00 AM
irocz's Avatar
Car: '87 IROC-Z
mine comes out the dash or the defrost or the floor just fine. it's the motor itself that will only come on when I set the vents to defrost.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
AkDrifted
Aug 17, 2015 07:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
