Desktop Dyno Anyone?
Old Dec 13, 2002 | 05:27 AM
wavslav's Avatar
anyone care to run the motor in my sig?
I am changing the head choice to what is listed in my sig and want to see if the previos/listed numbers still stand or get better.
Old Dec 13, 2002 | 06:36 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
this is the first time im using the program.im trying to learn how to input everything 100% but my best i have u rated at 565hp 456tq at 6500rpm.i wonder what other ppl have gotten to see if my calculations are off?
Old Dec 13, 2002 | 08:21 PM
vwdave's Avatar
I dont consider DD2000 to be accurate. Anyway....Here are a few variables I ran into...
Your disp. is 375.7 CI (I originally kept it OEM, and got a disp of 404.8, you had alot more torque, but when I destroked it, the powerband moved to the redline.)
I considered your heads to be "Canted/rectangular Ports, fully ported.
Intake Valve of 2.02" Exhaust of 1.60"
Your CC is 69.96 CC's
750 cfm carb w/tunnel ram
Long tube headers w/mufflers
Your cam settings to adv. specs.
The standard timing is 35*. I reduced it to 6* and picked up alot of power. (It does that with all engines for some reason.)
575hp @7500 (Redline, which is peak anyway.)
465lb-ft @5500.
I think these numbers are high, I would expect anywhere between 500-550hp.
Old Dec 14, 2002 | 12:04 AM
wavslav's Avatar
I think these numbers are high, I would expect anywhere between 500-550hp. [/B][/QUOTE]
Thanks for your effort.
I think mid fives is realistic also
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
